Bob, thanks much for the welcome back and offers!
My donor was a 2000 Imprezza Outback. The Subaru all wheel drive and auto trans is pretty intelligent as factory. The TCU monitors the ECU and some engine funtions directly. Since it knows engine speed, vehicle speed, vacuum (this was a non turbo vehicle) throttle position and braking the TCU knows to shift power to the rear when vacuum is low, throttle is maxed and rpms are high because it knows you are going uphill. If vacuum is high, throttle is at min, and brakes are applied the TCU knows you are going downhill so if shifts power to the front wheels. Under hard throttle the TCU sends a signal to the ECU to cut power to the coil for a split second as the transmission up shifts to lighten the pressure.
In my application the TCU is only getting info from the TPS and brake input. On this model it blinks a code on the trans oil temp light on the dash. Basically letting me know its missing connections. But in all my driving the trans runs as it should, yea! After tuning I will change the TCU oil temp light to an actual temp sensor to get rid of the flashing.
That being said, I had a great day playing with the laptop and learning to tune. And of course driving!
I rechecked everything under the engine bay and reinstalled the panels and the firewall. Gave it a good wash and wiped everything down with leather/vinyl cleaner. (I'm in the heart of Honolulu so I can't drive around a dirty car) I have the engine running well enough that if I feather into the throttle I can run up the rpms into boost without going lean.
Really need to get to the tuner now before I blow this up! Crazy fun!
Anyway, here is a quick video on a back road.
