10
65
View Poll Results: How to finish the mesh panels?
- Voters
- 57. You may not vote on this poll
Gloss Black
Unfinished Aluminum
Originally Posted by
JeromeS13
Double check that reservoir cap. It looks like an OEM radiator cap. If it is, it will not function correctly and will not allow coolant to be drawn back in after the engine cools down.
Yes, thanks!! I'll verify; I have the other (front -without tabs) cap sitting on my bench, and probably a third (aftermarket) in my extra parts box.
