61
403
Bob_n_Cincy
Did you check the oil pump to see if the pressure relief piston is stuck open?
The pump seem ok. No bits in the rotor and the pressure relief valve is closed and moves ok. I'm most likely not going to spend much time trying to track down the issue since I will be switching to a different power-plant and get to do all this custom stuff all over again.
