Fuel pump inspection
We purchased some foam blocks for inside the gas tank to reduce sloshing. While installing that, I took a look at our fuel pump given the recent issues others have experienced with the pump output hose coming loose. Here's what I found:
All is still well as we originally built it. We cut the OEM pump bracket and inserted a piece of steel. We used two self-tapping screws to secure the assembly along with a healthy dab of JB Weld. A stainless hose clamp keeps the pump in place. So far so good!
fletch
Where did you get your fuel blocks from? They are on my list, but there seems to be a lot of variation in price in what I’ve seen
roadrashrob
https://www.speedwaymotors.com/Fuel-...ach,52163.html
Bought 6, only needed 4.
