I tacked in a few pieces I was able to make out of the one tube I cut out. I think it is going to work out fine. I am fighting the urge to fully burn it in until I get the rest of the stuff in to validate everything. I ideally it would be the seat and steering, as well as, determining the brake line fittings that will emerge form the master cylinders to cut the clearance. I think I can squeeze it between the two frame members without having to notch them. this will likely result in my steering being about 0.5" inboard of the exact seat center. I think it will be fine. I would rather not compromise the tubes with a notch if I don't have too.
The angle on the left of the pic (toward the center of the car) will be different, this was just a quick mock up. There should be little to no interference with the real mounting solution.
