60
208
mcamera
Did you print it as a solid part or partial fill? Is it PLA? I think you'd want it to be pretty strong so your steering wheel doesn't fall in your lap while driving.
I picked up a solid piece of 1/2" Aluminum from OnlineMetals.com and will fab a bracket similar to the 3D model Ajzride printed, but with holes where I need them not grooves as I can't mill the grooves. Will also cut out a good portion of the center to shed weight/bulk.
