I was looking forward to pictures of the car upside down to bleed the air.
I've got a very slight coolant leak that only leaks when it's California cold (40's - not often). Maybe a tablespoon of coolant leaks onto the driver's side floor before everything is warmed up. I'm certain it's the hose clamp that ties the metal side pipe coolant line to the front of the car just behind the front wheel. Why haven't I fixed it? Because it will require taking the door, front fender and side panel off to turn a hose clamp screw half a turn and it only leaks a couple of times a year. Seeing your car without the body reminds me that I wish I paid extra special attention to those hose clamps that are inaccessible with the body on. Someday I'll fix it with a Gates PowerGrip.
