I was able to pick up my 07 WRX donor parts last week from a local Subaru wrecker and an 05 Legacy Spec B 6 speed transmission. I got luckily and they all came from the same vehicle. This week I was able to spend some time cleaning all of the parts. I was not planning on replacing the wheel bearings, but I needed to disassemble them to clean and paint the spindles. So I ordered new bearing and extended ARP wheel studs to make it a complete refresh. I was able to convert the steering rack over to manual and cleaned it up. I am not sure if I was supposed to try and save as much fluid as I could or not, but there was some that leaked out in the removed lines. IMG_0820.jpgIMG_0821.jpgIMG_0822.jpgIMG_0911.jpg
I then started the strenuous process of dieting my harness. I am more of a mechanical person so this is a little nerve racking, but with the FSM wiring diagrams and then this forum I am going to try tackling it myself. I was able to ID every connector and then began to remove all of the loom. It definitely makes a mess of your hands with all of the old tape residue. Next I will work on deleting each subsystem I do not need. I have some time before my kit comes in July so I am glad I am getting a jump on this now while I have the garage floor space to lay it all out. IMG_0914.jpg
I am not sure why my pictures end up upside down when posted. They all appear fine with I view them on my computer.
