Gotcha okay yea I am using my iPhone to take pictures. I will try to remember to rotate it next time thanks.99% of upside down pictures are from an iPhone. If you hold the phone do that you can use the volume button for the shutter (which apple enabled years ago) the picture will be upside down. You have to put the volume button towards the ground. If you have them upside down, you can rotate 90 degrees in edit, save, then rotate back.
