Originally Posted by
J R Jones
Your second photo shows the UCA on top of the mount tabs. Just in case... it should be between the upper and lower tabs.
FWIW I find the R & L box sections at the corners of my "S" footwells too big to be effective dead pedals.
Yes, but the R mounts the UCA on top of the tabs and uses a spacer or washer stack to fill the tabs. Then you need to use longer grade 8 bolts for the new required length.
