I cut off the factory mounts and made a pair 1.25” taller then welded them in place. Group n trans mount didn’t need modifications but I’m running a 5 sp. the taller motor mounts gave space below to incorporate my solid shifter linkage.
Ah okay I see what you mean now. Yes at first it was to have it sit down in the diffuser. I forgot about the earlier posts you referenced. I have some clearance now if the motor is raised 1.25” but it’s not much. I get what you mean about cutting the X out. I still need to raise the motor in the front.
This would be the cleanest method. I would need to figure out how to bend steel at home. I would think cutting and welding in flat pieces would not be the best or strongest approach.
