5
9
Raven225
I appreciate yalls responses.
As for the Hole in the back of the transmission: I believe that that port/hole is not pressurized. Correct? What I mean by that is it is not fed directly by the oil pump, but rather what came out was either sloshed or flung out by the gears/shaft left on the end of the transmission.
You are correct, that is not pressurized.
