Thanks Thanks:  6
Results 1 to 35 of 35
Thread: Lewma's Gen3 Coupe Almost Built Thread
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    All
    Should have done this a long time ago.
    https://photos.app.goo.gl/3ZyXcduhUmDeDQZD8
    That's my ongoing pic album that is documenting my build. No words, just pics. Hopefully the pics can provide help to other builders.
    -Gen3 Coupe
    -Blueprint GM427LS + T56
    -IRS, AC, Power Steering
    mark
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
  2. Thanks JimStone, Chopper thanked for this post
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    This is great, thank you! That's the Blueprint engine/trans combo I am interested in and there's not a bunch of information available for that in a Coupe.
    Which sized driveshaft is needed?
    Did you have any issues with the motor mounts or trans mounting?
    How much clearance do you have under the hood? Would there be enough for an aftermarket high ram intake or a supercharger?
    Thanks in advance
    - Jim
    Nov 2022
    Niles, MI
    Also, it looks like the oil pan hangs below the frame. Did you have a solution for that?
    Jan 2018
    San Marcos, CA
    Quote Originally Posted by JimStone View Post
    Thanks in advance
    - Jim
    Hello Jim
    - If you contact FFR and tell them the engine package you are using, you should get the correct length. I can check my inventory list when I get home for a part number
    - Yes, all kinds of fitment issues when it comes to engine mounts, trans mount. Had to grind a little off the mounts and the trans plate mounts. Nothing too much but just a little with the grinder. Had to design a completely new trans mount plate as the one provided in the kit did not work for this combination. My son drew up a design and we sent it to sendcutsend.com and they did the rest. We have the designs somewhere but I'm hoping by now that FFR supplies the correct plate.
    - There seems to be quite a bit of room under the hood. I can take measurements if you like
  6. Thanks JimStone thanked for this post
  7. #5
    Jan 2018
    San Marcos, CA
    Yes, the stock pan from Blueprint hangs a good deal below the frame. Worked with BluePrint and had to order the following:
    Oil pan:
    12624617
    Pickup tube:
    12624497
    Windage tray:
    12558189
    Dip stick:
    12570788
    Dip stick tube:
    12570787
    Pickup tube o-ring:
    12557752
    Gasket:
    12612350 or Improved Racing Part No. HGA-1001
    It still hangs below a little.
  8. Thanks JimStone thanked for this post
  9. #6
    Nov 2022
    Niles, MI
    Thank you Mark
    The engine sounds great in the videos. Are those the kit supplied side pipes and headers or did you go GAS'N?
    I assume you got the ECU from Blueprint. How is the tune out of the box? Idle okay?
    Which gear ratio did you go with for the diff? Thoughts so far?
    - Jim
  10. #7
    Senior Member Its Bruce's Avatar
    Houston TX
    What's the story on the throwout bearing?
    I just recently fired up my BPE 427 LS3 and the tune is good enough to fire up, but it's very far from being good enough to count on as-is. The first ECU had a corrupt VIN and wouldn't let me flash a tune. They sent another ECU and I was able to get in. The STFTs were immediately adding fuel due to a lean idle condition. I've since turned off all fuel trims and started MAF tuning at idle. I'll be driving it over the next few weeks to dial in the MAF before going after the VE table.
    MK4, 427LS3, IRS, T56 Magnum, Wilwoods
  11. #8
    Jan 2018
    San Marcos, CA
    Thank you Mark
    - Jim
    Jim
    Those are the standard FFR pipes, I just had them ceramic coated to fit the theme of the car
    ECU seems fine with the tune that is in there however I'm planning on a Lund tune once the car is on the road
    The diff is what comes with the IRS option from FFR. 3.55
  12. #9
    Jan 2018
    San Marcos, CA
    Quote Originally Posted by Its Bruce View Post
    The throwout bearing was leaking. After working with BluePrint and McLeod, they sent me a replacement bearing.
    I managed to separate the engine and transmission without lifting the whole assembly out and was able to replace the bearing
    No leaks so far with the new bearing
    I have some MAF codes that the ECU is throwing. Still tracking those down
  13. #10
    Nov 2022
    Niles, MI
    I see you mounted your reservoirs on the firewall behind the engine. I like that because it's out of the way but do you have trouble accessing them when the body is mounted?
    And is that a coolant expansion tank? Was that recommended by Blueprint?
  14. #11
    Jan 2018
    San Marcos, CA
    Its a little tricky with the body on but I wanted them out of the way
    Yes, that's an expansion tank. I read the cooling system diagrams on the engine then plumbed it in. Its likely larger than needed. Once I have more experience with this engine I may relocate it or use a smaller tank
  15. #12
    Nov 2022
    Niles, MI
    I was wondering: the LS 427 is rated at 625 hp, 565 ft-lb. So far, would you say that much power is useable as a street car? Would you choose something different if you could do it again?
    I'm thinking about the 427, but I also don't want to kill myself.
  16. #13
    Jan 2018
    San Marcos, CA
    Jim, its not street legal yet. We've just had it running around the street in go-kart mode. Yes its a step up from the coyote we have in our roadster, hopefully its not too much for street use but we'll have to wait until its running.
    mark
  17. #14
    Nov 2022
    Niles, MI
    Thanks Mark. Good luck on the rest of the build
  18. #15
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    My coupe has a SBF Boss 427 crate bored out to 460 cu in. 500 hp at the crank with 580 ft lbs of torque and a Sniper EFI. IRS with 3.55 gears. 18" tires. It is a beast in a 2600 lb car but IMO that's what these cars are designed for. Is it streetable ... again, IMO yes. Will I ever get it's full potential street driving? NO! By the time you shift into third you can be into triple digits. You most defiantly have to respect it but it is the most fun I have ever had in my 55 years of driving.
    Having said all that, you can have a blast in these cars with a mild 302! That motor is more than enough for a 2600 lb car. But if you want to take the dragon by the tail go with the 427 and hang on!
    Scott Pregont
    My Albums
  19. Thanks JimStone thanked for this post
    Likes lewma liked this post
  20. #16
    Nov 2022
    Niles, MI
    Quote Originally Posted by Namrups View Post
    Scott, your SBF Boss is a monster! The torque is ridiculous and that engine sounds mean as hell. You're right, the car is designed to handle it. It's more the operator I'm worried about. I doubt I have enough restraint to not put the pedal down at every opportunity, and those Michigan trees are oh so close to the road.
    Just from the re-sale standpoint the 427 makes sense though - if (gasp) selling ever was necessary. It gives that extra "fizz" factor.
  21. #17
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Jim Your right. It is all operator. You learn real quick what 1/4 throttle is. 1/2 throttle scared me the first time. I have not even considered full throttle yet!
    Scott Pregont
    My Albums
  22. #18
    Jan 2018
    San Marcos, CA
    Getting closer. This is a sample of the paint color we're going with. Porsche dolphin grey.
  23. #19
    Nov 2022
    Niles, MI
    Haven't seen many coupes in lighter colors. I'm excited to see how it turns out
  24. #20
    Jan 2018
    San Marcos, CA
    Started on the dashboard. Carpeting will start this weekend hopefully.
  25. #21
    Nov 2022
    Niles, MI
    Very cool custom design! Looks like a lot of work, haha
    What material did you use on the top of your dash and around the digital instrument panel?
    Have you had it out on the road much to have any more thoughts on the LS 427?
  26. #22
    Senior Member MSumners's Avatar
    Dec 2018
    Hudsonville, MI
    Looking great. Are the steering wheel buttons functional? Did you add a slip ring?
    Coupe Kit Delivered 11/10/23
    Roadster Build thread: 2019-2022 https://thefactoryfiveforum.com/show...4-Build-Thread
  27. #23
    Jan 2018
    San Marcos, CA
    Hi Jim. Its a work in progress
    The material is an alcantara. This is the first dash I've done using that and i'm still learning how it likes to stretch in some ways but not in others.
    Still not got much time on the 427 apart from go-karting around the street. Seems like it will be 'exciting' to drive
  28. #24
    Jan 2018
    San Marcos, CA
    Quote Originally Posted by MSumners View Post
    I have plans on making them functional at some point. Still sourcing a coiled cable and quick disconnects so I can hook them up.
  29. #25
    Houston TX
    Quote Originally Posted by lewma View Post
    https://www.motionraceworks.com/prod...-wiring-system
  30. Thanks lewma thanked for this post
  31. #26
    Feb 2018
    What did you use on the hood around the edge to build it up. Looks like sound kind of plastic channel. I need to do the same. Thanks
    Mark III 347/435 hp TKO 3.55 axle
    Gen 3 Daytona Coyote Gen 3 T56 3.73 diff. (In build)
    Superlite SLC LS3 480 hp Graziano Transaxle
  32. #27
    Jan 2018
    San Marcos, CA
    Quote Originally Posted by Papa t View Post
    Papa, that's standard drywall plastic corner that you can get from Home Depot or Lowes. My hood needed extending so I used that to form the shape but lined the inner sides with packing tape. I then filled the gap with HSRF but left it a little low on the surface. Removed the channel then filled the remaining with rage gold filler. Came out great. here's a pic of the hood today.
  33. #28
    Feb 2018
    Looks great. Thanks for the idea.
  34. #29
    Jan 2022
    Mark,
    I am in the midst of a similar LS3 build and I see you disassembled the engine fuse box(you are braver than I am). Did you eliminate the box altogether? I have been scrolling this AM as I was about to mount the fuse box on top of the panel over the master cylinders but without the body on I am afraid there isn't enough clearance.
  35. #30
    Jan 2018
    San Marcos, CA
    Yes, I deleted the fuse box altogether as I'm using a digital fuse system. Not entirely sure if there is enough room for the plastic fuse box above the master cylinders but you could test fit then use the firewall as a height guide. You should be able to open that box to replace fuses once the nose is lifted.
    mark
  36. #31
    Jan 2018
    San Marcos, CA
    Painter is done, hopefully bringing her home tomorrow if not raining
  37. #32
    Nov 2022
    Niles, MI
    Awesome! I'm a big fan of grays and blacks, so loving your color combo. Don't think I've seen one like that. Exciting to get her home
  38. #33
    Senior Member rhk118's Avatar
    Nov 2021
    Portland, Maine
    Great color combo, congrats!
  39. #34
    Nov 2022
    Niles, MI
    Lewma, your recent Google album photos and videos are amazing! The sound is just insanity!
  40. #35
    Jan 2018
    San Marcos, CA
    Thanks Jim. It was fun ( and loud ) driving her around the neighborhood.
    DMV is the next task
    Mark
