Thanks Thanks:  6
Likes Likes:  5
Results 1 to 11 of 11
Thread: Radiator reservoir vs Engine install
    May 2023
    Thoughts on mounting the radiator overflow tank before engine install? I’m thinking to do it after. Thoughts?
    Dublin, OH
    I suppose it depends on how big your reservoir is and where you plan on mounting it as well as what engine you’re putting in. More details might be helpful. I personally would tackle the engine first and then figure out where you can put the reservoir.
  3. Thanks MaxVmo thanked for this post
    Member Pmieras's Avatar
    Apr 2023
    San Tan Valley, Arizona
    Quote Originally Posted by egchewy79 View Post
    I second that
    Kit delivery (3/17/2024)
    FFR Mark IV Roadster (Ordered 11/9/2023)
    408 LS Stroker Powerplant Ready To Rock (link below of the first start)
    https://youtube.com/shorts/dH36tij3HK0?feature=share
  5. Thanks MaxVmo thanked for this post
    Likes MaxVmo liked this post
  6. #4
    FFR MKIII builder/owner
    Nov 2012
    Danbury Ct.
    If you’re thinking it might be easier to mount with a wide open engine bay you could always drill mounting holes before then do the actual mounting after engine install. As said I guess it depends on where it’s going and the size.
  7. Thanks MaxVmo thanked for this post
  8. #5
    Raleigh NC, OIB NC
    You did not say what engine you have but if its a Coyote & you are using a self purging tank you need to drop the motor in first. Peronally regardless of what tank I am using, engine first.
    Kevin
    MKIV #8234
  9. Thanks MaxVmo thanked for this post
  10. #6
    May 2023
    Sorry, details would be smart. I’m running a BPE 347, and the Factory Five reservoir. Good idea setting up the mount and then installing it afterwards.
  11. #7
    Dublin, OH
    You’ll have plenty of room with a SBF but smart to wait until after engine’s in
  12. Thanks MaxVmo thanked for this post
  13. #8
    May 2018
    Milwaukee, WI
    Quote Originally Posted by MaxVmo View Post
    So I was faced with this same decision during my build and, to more-or-less support most of the comments here, I am glad I installed the engine (and engine accessories) before taking on the overflow tank. I ended up having to move where I wanted to mount mine because an electrical item and the power steering plumbing ended up running where I didn't expect it. Just made the overflow tank install a lot easier.
    -Brew
    BUILD THREAD: The Brew City Cobra
    Current Build: MK4 Complete Kit, Delivered December 2021; First Start November 9, 2022; Go-Cart November 23, 2022; Carbureted 427W, TKX, IRS
  14. Thanks MaxVmo thanked for this post
  15. #9
    May 2023
    Thanks for the replies. Along the install lines, I’m considering where to put the hazard and hi-beam switches. Anyone mount them under the panel like on the support brackets?
  16. #10
    May 2018
    Milwaukee, WI
    I can't speak to the high-beam switch (mine is on the front of the dash as indicated in my build thread - https://thefactoryfiveforum.com/show...l=1#post509163) That said, you can also go with an old school "foot switch" if you want to completely do-away with a dash mounted high/low beam switch.
    But as to the hazard switch, I did put it under the dash to keep things clean like you propose. As an extra step, I also swapped out the toggle-style switch provided by FFR for a more modern low-profile switch so it wouldn't be as easily visible in that new location. Nice and easy and keeps extra clutter off the main dash.
    Picture of the underdash below:
    https://thefactoryfiveforum.com/show...l=1#post494848
  17. #11
    Dublin, OH
    I put an extra switch to the left of my horn button for my high beams and my hazard under the dash on a support bracket.
    I'm using the signal dynamics module for my turn signals that auto cancels and have a momentary button wired up for my hazard lights.
