0
0
Slop in rear rotors on hubs?
Anyone experience slop in the rear rotors regarding the stud holes? The router is snug on the center portion of the hub, however it isn’t snug on holes for the studs. I can rotate it between say the 12’ and 12:05 position. The front rotor doesn’t experience the same issue. On the front the studs have a shoulder that protrudes out more and fits securely within the holes of the rotors.
I’ve never seen this on any vehicles I’ve had. I’m assuming it has to do with the studs that were swapped from the original metric studs.
