Thread: 818s ---- clutch master cylinder wont fit under the frame any solutions?
    anderson
    my clutch master cylinder came from a 2002 impreza TSwagon
    did anyone else have this problem? What was your solution?
    Is there more than 1 type of clutch master cylinder by subaru that would work?
    Why doesnt it fit?
    Edmonton, Alberta
    I don't believe any of the non-turbo ones fit, my 07 didn't, and another member with an earlier model had the same issue. You can use the res from a wrx.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    anderson
    thanks ----- i thought someone else had this same issue
    kerry
    Exeter R.I
    Gotta use a 02-07 wrx one
    Nov 2012
    Medina, OH
    Or, since the windshield surround is pretty close making access tight for refilling, the remote reservoir mount kit that Michael Everson's put together might be worth considering. That's the route I went down.
    Rich
    anderson
    04 wrx worked fine
