Thanks Thanks:  2
Results 1 to 4 of 4
Thread: Mike Everson fan shroud mounting ?
    Jul 2020
    Spencer, MA
    I've got the fan attached to the shroud but now the inner nuts to hold the shroud to the radiator are not accessible because the fan is in the way. Anyone using this shroud, how did you do it? I can only think of putting 10-32 rivnuts on the shroud through a washer on the crush side.
    Norton, MA USA earth
    Either nutserts or just 3/16 rivets. One in each spot.
  3. Thanks Mastertech5 thanked for this post
    Sep 2022
    Huntington, IN
    I used nutserts
  5. Thanks Mastertech5 thanked for this post
  6. #4
    Jul 2020
    Spencer, MA
    Nutserts it is. All done, thanks guys! Backed up thin shroud with 18 gauge aluminum squares and JB Weld on the nutserts. I spaced it up from the rad using cereal box thick cardboard to keep it from rubbing on the rad from vibration. So I'm anal. I try to prevent future problems when I can.
  7. Likes Just 1 More liked this post
