Thread: Inertia Switch Orientation
    Sep 2021
    Hi all,
    I am getting ready to install my inertia switch and am wondering in what orientation it should be installed. Seems like it might be important, but I saw nothing in the manual (though I could have missed it).
    Thanks again!
    Tim
    Senior Member rthomas98's Avatar
    Aug 2012
    Ypsilanti, MI
    Vertical with the button on top.
  3. Thanks TTimmy thanked for this post
    Senior Member Alphamacaroon's Avatar
    Jan 2019
    Richland, WA
    I think I remember asking FFR once and they said that the orientation was not important. An inertia switch AFAIK is supposed to detect an impact in any direction.
    --jim
    Build 1: Gen III Type 65 Coupe, Gen II Coyote
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    No, orientation definitely matters. RThomas is right, it needs to be vertical with the button (the rubber cap) on top.
    Jan 2019
    Richland, WA
    Quote Originally Posted by JohnK View Post
    Yeah I take that back— you are right. If you mount it upside down it will still technically "work" but will be much more sensitive to false alarms like potholes.
    --jim
    Apr 2023
    Solana Beach Ca
    Just make sure its located in a place that you can get to, and if you are racing, make sure your crew members know where its at and what it does in case of a no start situation.
  8. Likes TTimmy liked this post
