Thanks Thanks:  2
Likes Likes:  3
Results 1 to 17 of 17
Thread: shocks
    southern delaware
    shocks
    I talked to Ted Harrison owner of Quick Racing Products. He said if we can get enough people wanting to upgrade shocks he will have another run made. For more information watch his YouTube video about it: https://www.youtube.com/watch?v=PvuLhHjW29Y ..
    He said he found running a softer spring and a stiffer shock the car will handle quite a bit better.
    You can contact him at:
    Ted Harrison
    [email protected]
    209 - 470-2979
    835 Avalon Dr.
    Stockton, Ca. 95215
    If anybody has anymore thoughts I would love to hear them.
    thanks
    nick
    May 2016
    Guestimet on $$
    southern delaware
    from Ted: I need to check with my supplier to see if the shocks are still available, will get back to you soon.
    southern delaware
    Just to follow up on this. Do not go to quick racing products. Ted said he can no longer get shocks and was absolutely no help what so ever on any alternatives or suggestions. I did get a recommendation on here to try ridetech shocks. They were very helpful and several other GTM owners have use their shock before. Fyi quick racing products does not sell the front sway bars anymore either. That will be my next adventure.
    Maricopa AZ
    I can do QA1 DA sets if you are interested. I just need to know the extended length you want and the spring rates.
    southern delaware
    can you help out with a front sway bar?
    Senior Member beeman's Avatar
    Indiana
    What's the issue with the supplied coilovers?
    GTM #304 LPE 525hp LS3
    Maricopa AZ
    hard to adjust with limited range.
    Maricopa AZ
    I can probably some up with a sway bar kit.
    southern delaware
    [QUOTE=beeman;510376]What's the issue with the supplied coilovers?[/QUOT
    the people I have talked to who drive there GTM on the street and track say the factory spring rate is too stiff and the shocks are too soft. you do not get much traction on rough roads and it is a rough ride. the softer spring rate gives you better traction but you then need sway bars. it does add a little more weight to the car but you get a better ride and traction. at least that is from the information I have read, being I have not installed any of this on my car I can't say from personal experience. I am relying on people much smarter than myself for this information.....lol
    I prefer adjustable shocks so for the street I can soften the shocks up for a better ride and if I am on a smoother track I can stiffen them up a bit.
  11. Likes beeman liked this post
  12. #11
    May 2016
    Quote Originally Posted by Gordon Levy View Post
    Interested.
    From what I have read, not what I know, front sway bar and lighter springs are a good setup for a street setup
    I tried to buy one that was previously discussed on this forum, but he was no longer producing them.
  13. #12
    San Diego
    The rear anti sway bar, in particular, is pretty hard to get on the car. I have seen a number of solutions, but here is mine...
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  14. #13
    Indiana
    Mike is that the PDG car or your GTM-r? What benefit did you see with the fabricated UCA, keeping the C5 LCA? Did you fabricate the UCA or is that an available part, are the upper mounts closer together than oem?
  15. #14
    San Diego
    That is the FFR PDG GTM rear suspension. I questioned posting that picture as I thought it might bring up a lot of questions because there is a lot going on there that you will not see on most GTMs. Basically I am giving away some of our secrets!
    That is a My Race Shop custom fabricated rear UCA. I did it so that we could easily adjust camber in the rear. I am still trying to figure out a suitable front UCA arrangement so we can do the same quick camber adjustments on the front. I have a few designs in my head but need to do some experimenting. The rear UCA is a drop in part to replace the C5 UCA. No mounting changes. You can see the shock is now much more straight up and down though. Wink wink.
    www.myraceshop.com
    GTM solution kits
  16. Thanks beeman, rolfer thanked for this post
    Likes rolfer liked this post
  17. #15
    May 2016
    Quote Originally Posted by rolfer View Post
    Just to follow up on this. Do not go to quick racing products. ... Fyi quick racing products does not sell the front sway bars anymore either. That will be my next adventure.
    FYI.
    Not sure what wormhole I managed to fall thought, but...
    I ordered, and just received today, a front sway bar (1.25) from Ted at Quick Racing Products.
    Their advertised lead time was 4 - 6 weeks, and he only missed that by about 500%, but he did come though!
    The parts are beautiful.
    He recommended going with 375# front and 650# rear springs with this setup.
  18. Likes Shoeless liked this post
  19. #16
    May 2016
    One more piece of the puzzle done, Thanks Gordon Levy!
    Double Adjustable QA-1's and 375# springs are in place.
    Front suspension is done, probably not but.
    Next the rear suspensions.
  20. #17
    southern delaware
    you are lucky to have that sway bar. he is not making them anymore and you can't get them. I am afraid if I put the stiffer shock and softer spring on my car without the sway bar it would not be good for the handling.
