Thanks Thanks:  2
Likes Likes:  22
Page 3 of 3 FirstFirst 123
Results 81 to 99 of 99
Thread: topherchrisb's project "Mako" Sub, Powder Coat, Lights
    Apr 2021
    Colorado
    Trans tunnel stuff
    With some of the added electronic goodies I have, I'll have a lot of wiring going back and forth through the trans tunnel. So I test fit the trans A frame, the trans mount, and the drive shaft safety loop just to help reference the amount of free space I'll have. Since I was there I put the drive shaft adapter in as well. I couldn't find any of the spacer hardware with the trans mount... but I'll be more worried about that when I actually have a drivetrain on hand and fitting. Want to get wiring mostly complete and some panels finally finished before that happens. It's hard to see in this picture but I built a couple of Z channels out of galvanized steel for each side of the tunnel to help hold the wire looms out of the way. The loom on the north side of the picture holds all the audio cables... low voltage rca cables to the amp, one rca for the back up camera, and two normal two wire speaker cables. You'll see how I'm thinking I'll route the extra 4g cable from the front battery to power the rear supplemental fuse panel and amp. It's going through some rubber grommets installed in the bracketry normally used for the parking brake cables. I'll add loom later when I'm sure it's what I want to do. On the south side of the picture I have the rear wire harness from the Ron Francis kit.
    Trans Tunnel:
    I plugged the ebrake cutout as most do when they aren't using the stock location or go with an electronic version. You can see some of the planned rivet locations for the z channel. They are the ones running horizontally up the middle here.
    I figure I would likely like to get the tunnel top off for serviceability but that's a challenge with the way the dash overlaps the center console . I could redo the console so it would go up under the dash but I doubt I'd like the finished product there. So for now I'm submitting to the fact that I'll have to take the dash off in order to get behind the console. Better get that wiring done right! With that in mind I chopped the front of the tunnel off to allow it to stay in place while opening the rest of it. You can see the harness carrying the audio stuff poking through the passenger side grommet here. Also look at that wiring mess... sometimes I feel I would have been better off starting from scratch on that harness. I've pretty much taken the whole thing apart.
    I added a rear panel to the console to mount the cross overs for the front speakers. I also de-pinned all the wires from the stereo harnesses I wasn't using to allow for less clutter once installed. I think I ended up taking about half of them out... even with less clutter it's going to be a challenge to get things hooked up in their final locations here. Again... better get the wiring done right the first time! Lots of testing.
    MK4 #10255 project: "Mako"
    Coyote Gen 3, TKX, IRS, Wilwood brakes, power steering
    Order date: 6/24/21, Received date: 1/12/22, First Gocart date: TBD, Registration date: TBD
    Build thread
    Apr 2021
    Colorado
    Dead Pedal Fitting
    Another thing I used as a break from all the wiring is the dead pedal fitment. I debated back and forth on actually doing a dead pedal at all. I have enough spacing between the clutch and the outside panel and my foot is skinny enough I could easily get my foot behind the clutch and into a nice cruising rest position. Probably a few cringe faces out there reading that statement with safety concerns. That's something I don't think I would be doing outside of long straight interstate travel but it's an option. I also bought the Breeze dead pedal kit to try out as another option. It's a simple kit with some angled aluminum and mounting hardware. The size of the pedal allows for the perfect fitment between the foot box chassis tubes when sitting flush with the kick out panel ledge. That also allows the ledge to increase the foot placement surface area somewhat. I won't really get to test it completely till I can get some seat positions finalized and make vroom noises.
    I did have to drill some recesses into the pedal to allow for rivets to countersink and sit more flush:
    Fitting:
    From the outside:
    Build thread
  3. Likes SuperFlyBriBri liked this post
  4. #83
    Apr 2021
    Colorado
    Rear wiring start
    I have made a lot of progress on the behind the dash wiring but have also started the rear power distribution as well. The rear components that exist so far are a couple of two post distribution terminals, a four channel amp, the aux fuse panel seen previously, and the wilwood ebrake controller. Probably the most interesting thing I've done here is I drilled through the ground distro block, welded a flanged nut to the square tube frame and ran a bolt through the distro block into the welded nut. I've added similar grounding points in a few other places that'll pop up in future posts.
    Top view:
    Grounding post:
    From the rear:
    Build thread
  5. Likes toadster liked this post
  6. #84
    Apr 2021
    Colorado
    Installing bulkhead fittings in rubber grommets for the transition from hard lines to flex lines makes me all kinds of nervous. The flex line is in constant motion when driving and when the grommet fails the stress from flexing will be transferred directly to the hard line. In time the hard line will probably see a fatigue failure. If I was a safety inspector I would fail the car based on those connections.
    Get some aluminum angle and make a bracket to fit the bulkhead fitting proper so you have a good ridgid connection.
    Hey Mike. I wasn't ignoring your advice here... I wanted to do some testing before I responded. I will go with your advice. The grommets I used are really robust and the way the bulkhead fits into them is surprisingly form fitting like they were meant for it. During my testing I saw something I wasn't expecting but should have in hindsight. The connection felt solid every time I tried to flex it. But your words "constant motion" made me change my testing behavior where I simulated flexing the line over and over as though the suspension was active over a period of time. Now I didn't have anything torqued to spec as the fittings are just temporary. What I found was it was easier for the fitting to twist in the grommet which started to introduce loosening of the hard line to the bulkhead connection and also the retaining nut itself. Likely torquing the hard to hard surface (flared surface) wouldn't allow that. But I can't really get reliable torque spec (especially over time) when mating metal to rubber. That is definitely concerning and not worth the worry. I won't get to fixing it just yet but it's on my list and will when I get some material.
    Build thread
  7. Likes Mike.Bray liked this post
  8. #85
    Impressive work. I would radius the corners of your dead pedal. Probably never know the difference, but something might get caught on the corners.
  9. #86
    Apr 2021
    Colorado
    Thank you... I did think about trying to put some finishes on the dead pedal that make it look more cohesive with the wilwood pedals, but haven't executed yet. So rounding and a pattern of holes or something.
    Build thread
  10. Likes Railroad liked this post
  11. #87
    Apr 2021
    Colorado
    More Wiring
    Well... I've made some decent progress. Still a long ways to go but getting it done one wiring at a time, and sometimes redoing one wire at a time, and possibly redoing a wire a third time. Everyone knows the drill. I decided I really want to be able to go cart early summer so I need to get my butt in gear. I should probably call Forte and see what his leave time is on coyote/tkx packages are soon. I'm assuming they aren't that long these days, but you know how assuming goes. With the new sense of urgency I started getting up much earlier than I have in a long time, going straight to the shop and getting a couple hours of build time in before the house is active. Definitely have some momentum right now but soccer, spring break and yard work just around the corner.
    There are sooo many wires in this build due to all the tech goodies I'm adding. A few things that may be out of the ordinary but mostly done in some fashion before... keyless ignition, brights relay system, stereo/nav, warning speaker, supplemental rear fuse panel, possible AC, and a few others that I think are really unique I'm not ready to divulge yet.
    I did get a headlight warning speaker from watson's street works. It's got a good mid tone triple beep sound pattern to it. It also has a read light ring for a visual queue as well. I wanted to be stealthy with it and wasn't really worried about the light so I mounted it into the dash under panel, just left of the steering column bracket. I didn't use the relay that had come with it though. The provided relay is only a four wire with a normally closed circuit. I got a hair brained idea and also wanted to wire the fuel pump inertia switch into it as well. So I needed a normally open circuit added for when the ground breaks on that switch. So now when a combo of no ign/headlight on or no inertia ground/ign on the warning is active. I had read a couple instances where people didn't realize their inertia switch was open and it caused a large waste of time on the road, so this will sort me out in a hurry if that occurs. The load for the speaker is small so I went with a medium size relay you can barely see behind the fuel pump inertia relay in the second picture. Another thing you'll see here are additional grounds. The large one forward of the warning speaker that goes up to a ground distribution block, and a bolt through the fuse panel mount to supplement my additions and the flashers.
    Build thread
  12. #88
    Apr 2021
    Colorado
    Wires... they're everywhere
    Here are a number of pictures displaying the progress on the tidiness of the wires. Still doing tons of testing so will have to re-loom most things... but I was able to get the gauge/switch wiring cleaned up. Just five 6-pin molex style connectors and an extra run for sending units(and I don't even have AC controls picked out yet).
    Behind the dash with it in place. Still not re-loomed
    Some wires for the wipers and AC if I end up going that route. Plenty of room still too.
    The rear is still even more of a disaster while testing. I did get extra wires ran for the cubby lighting, rear fuse ign trigger, rear view camera, etc...
    Build thread
  13. #89
    Apr 2021
    Colorado
    Testing the wire mess.
    I am constantly testing things as I add runs and connect them. I am making everything so I can get it apart once the body is on... but it's not going to be fun. So double and triple check everything!
    IGN, headlights, turn signals, brights, pilot lights, stereo power, fuel gauge, switch panel... check! The switch panel won't go in place till I get the transmission in and can properly space everything on the tunnel. You can see I still have one blank in there that I don't have a use for yet. I took the picture with the hazards on right when they flashed so I could get the pilots in an active state in the picture. I also did check the turn signals individually to make sure my diodes were wired properly with the single output hazard switch. I do have the speed hut dimmer that can cycle through six different gauge brightness levels. The button is mounted to the back side of the square framing behind the starter button. It also has the button for the manual override of the ignition system. Both of those tested with success as well. I also calibrated the fuel gauge and moved the float manually to verify it's in working condition. You can see the low fuel warning light active there.
    Speaker amp, stereo sound... check! I got these JBL GTO939s due to them being recommended for open air environments. Still it's an open air environment that'll hopefully get a more full sound with the body on and the trunk shut. I had to tune the EQ on the stereo quite a bit to get the low end depth I was looking for. I think I might add an all in one 8" sub enclosure to get the bass drum punches I like. I still have to finish the runs for the front speakers. Only have up to the cross overs wired there so far.
    One of the reasons I went with the stereo I did go with. I don't have the antenna positioned or the sensors installed in the wheels yet... so nothing to display at the moment. I did do a bench test with everything connected and a tire pressure warning pop up appeared on the screen while in navigation mode. So pretty confident it'll work as intended.
    Build thread
  14. Likes GTM_Vet liked this post
  15. #90
    Apr 2021
    Colorado
    Brake/Reverse testing
    One thing I wanted the capability of doing but still on the fence is a reverse view camera. With that I wanted the stereo to show the camera view automatically when in reverse. I don't need the speed sensor wiring in the RF harness with a coyote/gps gauge setup so I repurposed those wires for a reverse switch I'll put in the transmission when I get to that point. I used the gray wire as an IGN feed and continued that feed to the rear fuse panel for it's IGN trigger source. Then I used the green wire for a reverse trigger to the stereo and ran an extra feed to the back feeding a reverse light through the drivers side rear harness. I put a clamp on my button so I could take the picture. I tried to capture the rear view mode on the stereo but it's too far away to tell it's working. I just temporarily set the camera on the top trunk shelf behind the pliers. It's hard to see as well.
    I'm still testing and on the fence about the third brake light as well. I re-added the purple brake light feed into the harness before the trailer light conversion in order to allow it to feed that possible third light. Here is my temp setup for that test.
    Build thread
  16. #91
    Sep 2011
    Minneapolis, MN
    Quote Originally Posted by topherchrisb View Post
    You have better foresight than I did. I put my dead pedal in almost the exact position you did. And I do use it. But for this six footer with narrow feet, while the dead pedal is plenty comfortable and still allows plenty of room on the pedals as well, my favorite cruising position is with my left foot stretched out under the clutch. Something I never anticipated and not great for safety but sure is comfortable.
  17. #92
    Apr 2021
    Colorado
    Low Profile Sub and Charcoal Canisiter
    Two months can go by just like that. Soccer, spring break, school assemblies, field trips, colds and boom... you realize you haven't made progress on the project much at all. Another excuse I have is the lack of gen 3 coyote crates available. I really thought I had enough momentum going that I would want to order a motor in April. Well by the time I got around to it the Gen 4 hadn't been announced yet and the gen 4 aluminators didn't have wire harnesses available. I did get a quote for a gen 3 aluminator SC from Forte but I truly didn't want spend the extra money with no intention of forced induction. I was patient and the Gen 4x announcement happens. So I'll be looking to get one of those in the near future.
    I mentioned earlier I would like to put a small sub in to have a little more thump behind the bass drum hits in the tunes. I ended up getting an "all in one" JBL enclosure that had some decent ratings. Some extra wiring in place, a few mount points configured and we are up and running. Nothing is permanently attached yet so it just rattles all the sheet at the moment, but it's very effective.
    With that completed I just needed to run some wires off the supplemental fuse box to the seat positions for any electrical there and I was confident I had the rear wiring all figured out. I couldn't terminate the wires though as my connectors would not fit through the pass throughs I've put in the panels. I didn't want to make the holes any bigger than I had to... so I need to finish the panels and get them attached permanently before that happens. Part of that is something I've ignored for a while now but needed to find it's final resting position too, the Charcoal canister. Nothing crazy here... PVC, barbed fitting and an antenna pole mount and that was taken care of. Just need to put some paint on, find better fitting hose clamps, and fill it full of material.
    Build thread
  18. Likes SuperFlyBriBri liked this post
  19. #93
    Apr 2021
    Colorado
    Trunk and Cubby lighting
    In the previous post I said the rear wiring was done. But I hadn't mentioned any of the trunk lighting yet. I have a "cool blue" light working in the cubby location. I'll have the same color for the front courtesy lights working off the same trigger points. Those being grounding switches on the doors and one of the buttons on my programmable switch panel. The voltage runs through a fade in/out LED controller to give it a little more cool factor when they come on. Picture is just a side shot without the body on so the lighting is flooding everything but you get the idea.
    In this picture you can see the inside trunk lighting. This LED strip is a "cool white" strip and runs directly off the electronic trunk latch. The wiring here was another one of those things I redid a couple times. I wanted a pilot light on the dash to come on if the ebrake was on or the trunk latch was open. Well not realizing the wilwood brake controller switch light was ground controlled I had wired the trunk with the opposite polarity in mind. After a few different setups and a new diode in place I got it all working. I don't have a picture of the dash light but it is a standard parking brake light in red matching the size of the turn signals I've shown previously. The wiring consists of the dash light always being charged positive while the trunk and wilwood switches completing the ground. The diode simply just keeps the wilwood switch from lighting up when the trunk is open. You'll also see the brackets I made to mount the lighting. Some simple flexible light C channel and some galvanized sheet I had sitting around.
    Build thread
  20. #94
    Apr 2021
    Colorado
    Powder Coating
    As I was starting to get pieces finalized and wanting to attach them in their final places permanently, I decided I wanted to take on powder coating the smaller pieces myself. I got a decent size toaster oven, a small paint tent, some powder and a powder coat gun off amazon to try my hand at it. I started with those lighting brackets I had shown in the previous post. Those I could mess up and no one would know the better. I don't have a picture of them complete at the moment... I'll try to remember to get one next time I'm out there taking pictures.
    I want to go the black out route so TONS of parts to prep and coat. There are some bigger pieces I'll have to take to a pro shop but it feels good to get some of this stuff done myself. I got a flat black which I really like but worried about longevity when trying to clean it. I can imagine it slowly turns more satin as you try to keep it clean? I also tried multiple coats on a couple pieces to see if I could make things a little more robust. You couldn't tell looking at them but you can feel a difference. The second coat doesn't go on as smooth as just a single coat. Maybe just the way I'm doing it? Probably just need some more practice. I also need to figure out what I can do for some sort of clear coat on top. I think that'll help keep the finish more consistent over the long run but realize that'll probably add more sheen to the look. There are clear powders you can use but not sure if it's worth the effort over just finding a hard spray clear or maybe even a ceramic coat. If anyone has any experience/opinions there I'd love to hear them.
    Build thread
  21. #95
    Apr 2021
    Colorado
    Body Lighting fitment
    There are a couple of pieces I want to position with the body on. The main three right now are the coolant expansion tank, the cool guy fan controller, and the tilton brake/clutch reservoirs. I dropped the body down a bit and decided to do some light fitting before I put it on completely. That'd allow me to size up and finish weather packs for the lights.
    I still need to take the bezels off for the rears and powder coat them but getting the placement down. They aren't exact with the shape of the body... but with the pre-drilled holes not much room for interpretation. I'm assuming a body guy will want to do the massaging there when it's time.
    Now it was time for me to start working on the front turn signals. I got a set of jeep halo turn signals to match the look of the halo headlights. The have a smoke lens over them too which I like. I needed to figure out how to make them fit to my application though. Here you can see I had to un-soldiered the wiring in order to get it all taken apart. I had the one supplied in the kit torn apart too so I could try to create a plan. It ended up being fairly straight forward. Cut the square mounting plate to my needed round shape, re-soldier the connections, drill some holes in the matching mount positions, epoxy some machine screws, re-assemble with black sealant for weather proofing.
    Finished turn signal
    And here you can see the turn signal in place. I also fitted the headlights... one I had finished powder coating the trimmings black by this point.
    The turn signal does look a little goofy from the side as it has a pretty deep profile. I've started designing a bezel for them which should be a softer transition and fit the curves of the body molding better. This is my first CAD/3D printer project so plenty to learn here too.
    Build thread
  22. Likes Mike.Bray liked this post
  23. #96
    Apr 2024
    Pembroke, GA
    Very nice bro! I applaud your attention to detail! This is going to be killer when completed! Look forward to seeing more updates!
  24. #97
    Apr 2021
    Colorado
    Quote Originally Posted by GTM_Vet View Post
    I appreciate the words. I've put a bit of time into this project. I really want to be able to drive it as much as possible. So trying to check all the creature comfort boxes. Honestly though... I could slap an engine in it, put the wheels on, drive it around in gel coat and probably be happy for a quite a while.
    Build thread
  25. #98
    Apr 2021
    Colorado
    After yesterday's post I was able to spend a little time on the car.
    I did get a picture of the completed rear courtesy lighting brackets. Here they are powder coated, riveted on, and with the lights pressed in place. I thought about painting the sides of the silicone encasing the LEDs to have them blend in more but the light does leak through the sides a bit. They'll also be tucked up under the body rolls and hardly visible anyway.
    I also got my test turn signal bezel fitted to the light. Here you can see the profiles of one with the bezel and the other without.
    Here is the initial test fitment to the body. You can see how far off center those holes are drilled from this angle. I think that's something the body person will probably be able to fix easily.
    I liked the way the first version of the bezel fit so I printed another one. They had a deal on these elegoo neptune 4 printers a little bit ago. Very good ratings as a first 3D printer so I took the plunge. Took me a bit to get all the software working, calibrated and configured but it's working fine for what I want.
    Build thread
  26. #99
    Folsom, CA
    awesome job on the 3d printing!!
    are you using suitable product for UV protection and heat?
    Todd
