Results 1 to 13 of 13
Thread: Totaled '04 WRX, $5K, Aftermarket parts
    May 2013
    Totaled '04 WRX, PPG straight cut 1-4, Cobb, Sti, EJ20
    My '04 WRX was totaled in an accident on 04-05-13, front end damage, both airbags deployed, Driver's side is scratched up/dented, the windshield is cracked, drivers side rear taillight is cracked, small dent bottom center of trunk. Selling it for parts.
    Selling as a whole for $5,000, this is a firm price.
    Engine starts up just fine. Trans shifts through all the gears smooth.
    78,445 miles
    Parts of note on it:
    PPG Synchromesh Straight Cut gears 1-2 and 3-4. Tranny was rebuilt 14k miles ago everything replaced with brand new parts, have receipts.
    Cobb Anti-sway bar kit, Front and Rear
    Cobb Sport springs
    Cobb short throw shifter
    STI seats and door cards, front and back
    Tires, brakes(all 4 pads and front discs), shocks, struts and O2 sensor replaced 4k miles ago. Have receipts.
    Did a lot of work 4 Days before the accident, Have receipts.
    Items replaced with new parts:
    timing belt
    water pump with gasket
    two smooth rollers/idlers bearing with bolts
    one cogged roller/idler bearing
    auto tension adjuster
    tensioner bearing for auto tensioner arm
    thermostat
    thermostat gasket
    two drive belts
    four camshaft seals
    front crankshaft seal
    valve cover gaskets, grommets, half moons(driver and passenger)
    spark plugs
    cleaned the MAF and IACV sensors(replaced IACV gasket).
    Fuel filter
    Air filter
    It is located in Paonia, CO 81428.
    Email or call, text @ 97o-27o-oo22 if interested I will be happy to post more pictures talk with you about it.
    Thanks everyone.
    May 2013
    bump
    May 2013
    bump
    May 2013
    bump
    May 2013
    bump
    May 2013
    bump
    May 2013
    bump
    May 2013
    bump
    May 2013
    bump
    May 2013
    bump
    May 2013
    bumped
    May 2013
    bump
    12 posts, no other forum interaction. Every post a bump for your own classified ad.
    Please read the following:
    http://thefactoryfiveforum.com/announcement.php?f=30
    At this point, if someone has interest they can contact you via your posted info.
    Closing thread.
